Sorry for the long post but I’m looking for some guidance.
The pool company has been receptive and working with me but I was wondering if there is anyone who has experienced this before. Last year a few times (maybe three) while the equipment / pool was in spa mode with the heater on and the blower on, one of the breakers at the pool pad would trip and turn off all the equipment. When I would go over to the pool pad to inspect, I noticed some water under the UV/Ozone box as if water leaked out of it. I would flip the breaker back on and not have any issues getting the equipment back up and running. I would monitor the UV/Ozone leak when I put the equipment back in pool mode and it would dry up and no longer be leaking. During the last time it happened last season, when I put the equipment back into pool mode it sounded like the pump was running on high (app showed it running at 100%) but the pump was hardly pumping any water into the pool (spa wasn’t overflowing, etc., the filters were cleaned and the pressure of the filter was not high). Pool company came out and we couldn’t get the equipment to replicate the issue I experienced.
Does anyone have any idea what’s going on? When the equipment is in spa mode is it creating to much pressure and causing a leak in the UV/Ozone box and the heater and there is some sort of safety feature that if those two units detects a water leak it trips the breaker?
Any advice is greatly appreciated.
Thanks in advance.
To note, the water/wet spot I’ve noticed under the UV/Ozone box & the heater are only there when the equipment is in spa mode with the heater on. It’s not a leak as water is continuously flowing, it appears to drip for a few minutes to create a wet spot under the equipment and then it stops. I’ve also previously used the heater to heat the pool in pool mode and the heater ran for 3ish hours with no issues (not kicking off, not leaking, not tripping the breaker) and brought the pool temperature up 9ish degrees.Fast forward to this season, I have not experienced the breakers tripping at the pool pad and we have used the heater to heat the pool a few times with no issues.
We also used the heater three times to heat the spa and use the spa. The first time was on 05/29. During that time, the heater would continuously kick off but I would not get a notification on the OmniLogic App. When I would go over to the equipment pad I lifted the window on the heater and it had an orange light by the triangle and displayed Lo. Doing some research I came to the conclusion it was low water flow into the heater which didn’t make sense because the pump was on high and the pressure on the filters were not high and within range. Turning the heater off and back on would solve this problem, it would start up heating again for a few minutes before it would kick off again. We finished swimming that night and the next day (05/30) as a precaution I cleaned the filters which were not too dirty.
On 06/18 we used the heater to heat the pool and we also used the spa again to include the blower and the heater. While using the heater to heat the pool we did not have any issues with the heater kicking off and having that Lo reading. However, while using the heater to heat the spa, the heater would continuously kicked off, have that orange triangle illuminated and would read Lo. When it first happened, I went over to the pool pad to inspect and noticed water under the UV/Ozone box, the orange triangle lite up on the heater window and the error code of Lo. Turning off the heater and turning it back on solved the issue, it would start heating before kicking off again. We finished the night swimming and I left the pool in pool mode to end the night. I monitored the leak from the UV/Ozone box and it appeared to stop like it did last season when the equipment was put back into pool mode. Also, there has been some water under the heater when it’s on but I assume that condensation?
The pool company came out a few days later and could not get the equipment to replicate the issue but did advise they noticed a small leak coming from inside the UV/Ozone box.
Fast forward to this past weekend, on 07/22 we used the spa again and had the equipment in spa mode. At first, the breaker would continuously trip and I would go over to the equipment pad and flip the breaker back on. Eventually the breaker stopped tripping and then the heater
would continuously kick off and back on. The first time it tripped I noticed water under the UV/Ozone box, the second time it tripped I noticed water under the front right side of the heater, the third time it tripped I noticed water under the front left side of the heater. After the heater kicking off and back on a few times by itself I eventually turned it off to prevent any further issues.
Thanks in advance.
