I have a hayward hd135id heater. I had to replace the heat exchanger after only 2 years. After this I get a bd error code. When I reassembled the heater and plugged it in the fan came on immmediately and ran for about 10 seconds and shut off, but there was no display. Iopened it again and checked the display ribbon cable and it is slightly loose at the board. I pressed it in again and then restarted the heater, the display came on and shwed 64 degrees for roughly 5 seconds and tripped the bd error code. The fan never turned on before the code was kicked out. checking the ribbon cable again caused it to kick out a CE code and the fan came on the same way as earlier. pushing in the cable again cleared the CE code but no fan and kicked put the bd code. So, when the display iworking correctly, no fan and bd code. When the display is off or CE code the fan comes on at stsrtup. Could a bad ribbon cable cause a bd code? Is the fan supposed to come on when plugged in?
any help would be greatly appreciated.
Thanks Rich.
Thanks Rich.
