Hayward H400FDN Codes
Sgt1411
92
Goodyear AZ
Hayward Aqua Rite Pro (T-15)
Giving this thread a bump as I am experiencing the HS/LO codes now too, exact same issues. Heater goes until 85-90F then throws HS code then LO code.
Bypass valve is closed so water should be full pressure into heater
The Hayward SwimClear filter (8) pressure shows fluctuation between 11-12PSI when pump running. Is that too low time to clean filters?
Moved from here.
What is your clean filter pressure?
That's a good question I honestly cant remember I thought it was much higher then 11-12PSI but that wouldn't make sense, isn't it supposed to lower pressure when clean and higher pressure reading when dirty or obstructed?
Yes. If you do not know the clean filter pressure, time to clean the filter. Then record the data point (with the corresponding RPM). When it rises by 25%, time to clean the filter.
