I screwed up badly. When I closed the pool last year, I failed to drain the filter. So, the head has a big crack. It's a Hayward DE3600 and the head part is discontinued. An exhaustive search on the web did not turn up the part (DEX3600BT). So, I am open to any suggestions. It's Saturday and I assume Hayward support is not available.
So, my questions are:
-Does anyone know where I can find a replacement head?
-If you think I will have to replace the filter, what do you recommend? Pool is ~20,000 gal. I get a fair amount of organic matter from pine trees and other trees. But with the DE3600, it has not required frequent servicing of the filter. I've been happy with the water quality using the DE filter and maintaining it myself, and don't think I'm interested in a sand filter. I know nothing about cartridge filters, but would that be a simpler or less expensive system?
Pump is Hayward 3/4 hp, single speed, and is relatively new, compared with the filter. Also have Hayward SWG.
Would a new filter require a new valve? I have the Purex Triton valve, 27-1141, 8/98, SM 10-2DE.
Help, please! And thanks.
