I am seeing very similar thing. If Avg salt reading is 2300 or less, then the panel will not generate. If I reset the Avg. Salt reading per the Hayward Trouble Shooting Guide:I tested salt 3000
But I constantly get this
Could cell be bad?
I can get the Avg. Reading above 2300 and it will generate for a while and I do not have the error lights.....a day or maybe two then the Avg Reading goes to 2300 or 2200 and I do the dance again.
My salinity level is 3200 per Leslie Sample testing.
That Guide also mentions if the Avg Reading is < 75% of the actual salinity it is time to change the Cell.
I am in process of replacing cell, trying to determine if I can go down from a T-15 to a T-9 for a 12k gallon pool.
Did you replace your cell yet....and if so did it work for you?
Moved from here.
