This is my 4th season of our pool. I used a different pool construction company to close in Nov and open last Fri, 5/8. Pool maintenance came Thurs put in some salt and said good to swim next day Fri, 5/15. I started heating the pool Fri morning starting at 55 degrees and it got up to 75 degrees by around 3pm. My kids wanted to skip and just get into the spa instead so I toggled over to spa mode using the AquaConnect app on my iphone. We noticed the spa didn't heat up quickly like usual and I realized it was still in spillover mode sucking the pool water into the spa. I also noticed on the AquaPlus panel if I switched between pool and spa the pump didn't stop and re-start as I noticed it did in previous years.
I called both companies and someone from the maintenance company had me switch the valve positions. Of course I also started to hit every button/setting on the AquaPlus control panel. At one point on the AquaConnect app there was no longer the Pool/Spa toggle and only Spa filter perhaps. The pool maintenance person said he was going to come back that night to take a look but did not. As I was sitting by the pool at night I heard this draining sound and realized the spa completely drained and only the jets had water coming out of them. I turned off the pool completely and turned the valves back to the original position so the pump wouldn't get damaged. When I did that water started flowing back into the spa from the pool.
He did come back today and turned the valves back to the position he told me to do. He also explained the equipment layout better and marked with a Sharpie. He said something is not configured properly and the Hayward system is not recognizing the spa at all. He will come back Monday and do a support call with Hayward to work through it.
Everything seems to be completely mis-configured. If I click on the button for my waterfall feature (labeled Aux1 on control panel but Spa Filter on AquaConnect app - this used to be Aux1 also) the panel switches from Pool to Spillover and then the heater light illuminates even though the heater was showing Auto on the AquaConnect app. The AquaConnect app now shows only Pool/Spillover as toggle options. Here are some various error messages displaying on the AquaConnect app:
Spa Temp error
Spa Filter - VSP Comm Error
Check System - Spa Sensor Open
I know very little about how to use my pool as the pool builder basically abandoned me at the end of the project to fend for myself. I've managed to do the basics for 3 seasons and expected to do the same again. I'm fairly certain all my button pushing caused my current predicament. However, it seems something was off with the spa before I interfered since it didn't switch out of spillover into just spa mode when we wanted to heat that on its own. The only change this season is that I used a different company to close in fall and open this spring. Do they change those valve positions during those processes?
Wow - apologies for the novel. I dislike being self-sufficient and I guess this mess will finally be the kick in the pants to learn how my pool works. Thanks!
Spa Temp error
