Hayward Aqua Plus Pump Programming
thadius65
441
Bloomsburg, PA
Can anyone verify the ability to do the following with a Hayward Aqua Plus system?
With H400 gas heater and dual speed super pump connected to Aqua Plus, can you set it to run always on low speed unless heat is called for and then run on high until temp is satisfied?
Going through manual and not finding verification unless I am missing it.
Thanks!
Ted
I think I found my answer:
Allow Low Speed
This menu only appears if the filter is configured for 2-speed or variable speed operation. During
default operation, high speed mode is used whenever the heater is on. If Allow Low Speed is enabled,
low speed will be allowed even if the heater is on.
Ted
