hayward aqua plus: check system light on
Feneche
59
Las Vegas
Check system light is on and I Cant figure out why
I read here that Some people can see the error code or error message
But my system dont show anything
The SWG seems to work good as far as I notice
Tnx a head for your help
CSM stands for (Chemistry Sensing Module), this error appears when Sense & Dispense is enabled, but the Chemistry Sensing Module is not found.
Do you have Sense and Dispense?
If yes, verify that it's plugged in.
It’s a separate system for PH and ORP monitoring and a total waste of money. I’m guessing that you don’t have it and have it enabled which is why the error. Should be able to disable it in the configuration menu I believe.
Salty
Are you new to the pool?
Do you have a picture of the system?
How old is the equipment?
Tnx for the heck
Yes,I'm kinda new to all the pool maintenance thing
I got the this model
The equipment is new no more than a year old
I will look if there is any enable... and see if I can disable it if I will find it
