- Oct 25, 2015
- 5,216
- Plaster
- CircuPool RJ-60 Plus
My Hanna Phep pH probe is 11/2 years old and still going strong. It holds calibration for 2-3 weeks and even then is never more than .1 pH unit off. So it calibrates quickly. I've even let it dry completely out a couple times and after re-hydrating in storage solution, calibrating it came right back.
Last night I messed up pretty bad and accidentally calibrated with pool water that was pH 8.1 instead of the standard 7.01. That really messed it up and when I tried to calibrate with the right solution it gave an "err" message followed by a "clr" message. I thought this would clear the bad calibration but it kept giving me the "err" message. So I dug up information on Hanna's site that indicated I needed to place the probe in cleaning solution for 15 min then re-calibrate. I figured this was a long-shot but tried anyway. Voila! It worked. Calibration was completely normal and it's working fine with no "err" message. I've read there are many owner that get 3+ years from this tester although Hanna indicates 1-2 is normal. So I'll keep plugging away with this one 'till it fails.
I hope this is helpful for those out there like me that have a tough time with the phenyl red ph color test.
Chris
Chris
