Handy Chart for Adjusting?
May 19, 2016
30
Bristol, CT
I was curious if there was a reference chart for what to add in order to adjust certain levels? Like....increase pH - do this; decrease pH - do this.
There are a couple around the interwebs, but I was curious if there was a TFP-approved visual aid. Thanks!
Since it differs by pool size/type, you could also use PoolMath to see what to do on your pool size to add/subtract 1ppm of each thing, and put it on a small laminated card with your test kit. On the other side of the card put ideal values and acceptable ranges for each. So then you test and see you need 3ppm of FC, you know exactly how much bleach to add without going to the calculator.
