Hi ,
We had a new liner placed and needed to refill our pool with our community well water. When the pool was full, the water looked greenish/ Brown. We knew we had iron in our water, so before doing any chemical balancing, we added Polyfill in nylon socks to our skimmers, and seriously within 2 days the water was sparkly clean.
Then we started to adjust our chemicals. First results of water ( prior to adjusting):
Cya 0
TA 220-240
PH 8.0
FC 0
CH 275
Salt 0
First we adjusted salt. Now 3300
Then the cya: now approx 55
Today did the TA/ ph: TA still 190. PH 7.2 ( tested 2 hours later)
Shortly after this noticed water was looking a little darker, didn’t think much of it.
I placed a question on this website ( concern for still elevated TA) and if I should work on this further or if ok to adjust chlorine. Got the go ahead to adjust chlorine.
Chlorine now 4. However water now looks greenish/ Brown like it did in the very beginning.
I’ve cleaned the filter, added the nylon Polyfill stockings again. Hoping it’ll clear up again over night.
Am I silly to think I can filter out this iron, or do I really need to add sequestrant? I’m puzzled because prior to this, we haven’t had to add any sequestrants to our pool and we’ve had it for almost 7 years and it was filled by the same well back then.
I was hoping to avoid adding sequestrants because then I have to add it regularly, etc. any thought son this? If I do need the sequestrant, can I add this even tho my pH is only at 7.2? Can I add this while adjusting my other chemicals? Also typically how long does it take for iron to stain a vinyl lining? Our liner is new, so I’d hate to have this stained right away. Any thoughts/ advice greatly appreciated.
If need a sequestrant, any preference on which kind? One other question re: my pH, can I use borax to increase my ph and if so, will it aff3ct my other chemicals?
Thanks again,
BK
I
Cya 0
TA 220-240
PH 8.0
FC 0
CH 275
Salt 0
Thanks again,
BK
I
