Hey yall! It's been a very long time since I have posted anything here, since my pool has been perfect for years. However, I am now running into a problem, so I knew exactly where to come. I replaced my liner last year, everything was perfect. However, I became very ill in the fall so I wasn't able to close down properly. I finally was able to start working on my pool again late April. I have been slamming since then, but I still have very green water. I know my CYA got too high since I couldn't find bleach anywhere and I had to use the dreaded "shock" packs - dichlor. I have drained, replaced, and drained and replaced a lot. My CYA is down to 60. I would like to get to 40. I drained and replaced last night again so I am hoping I got down to at least 50. I started being able to buy bleach again about 3 weeks ago, so I have only been using 7.5% bleach for a while now. My FC was 28 last night, and I even added some more bleach to get up to mustard algae shock levels in case that's what I was dealing with. There was literally no change in my water at all. I have vacuumed to waste several times, I have scooped out all leaves at the bottom and I am certain there is nothing left down there. I am at the point of wanting to drain and refill. Since my liner is only a year old, can I still do this without damaging it? I was thinking of putting the shop vac suction on it like they did when it was installed when I begin refilling it. Thoughts? I haven't tested this morning, but all levels (except a pretty high FC) are in range as of last night.
