Hi All,
I have a ~14k gallon pebble tech pool in AZ(hot). I have two mesquite trees in my backyard meaning frequently dropping leaves and pollen/flowers in the pool. Pool is about 25 years old, purchased home 4 years ago.
My pool guys struggled to keep my water clear, he wanted to drain and acid wash it, and quit when I didn't want to move forward. I've been using test strips and adding chlorine as needed based on test strip data for the past year or so. Results are the same as the pool guy... I brush about every 3 days and when I do you can see the green algae coming off the walls and where the vacuum misses, if I wait for a week to brush my pool after I brush my pool is totally green and I can't see the bottom. I've went to the pool store, and they said my biggest problem is total dissolved solids and I need to drain my pool(drain half way fill, and retest chemicals), they said I'm wasting my money adding chemicals until I do...
I picked up a TF-100 kit and just did my first test and my levels seem way off to the point of after adding 70-80 drops and the color not changing I just stopped.... I was very careful with all my measurements and rinsed everything before taking any readings. Please note I added chlorine pucks this morning in case that has any impact. Below are my readings per my test strips and the TF-100. I would really really appreciate any help, as I was excited to get the kit but really disappointed my levels seem so far off I'm wasting the testing chemicals and not even getting to a known level...
Test strips:
Hardness: 350
Total Chlorine: 25
Free Chlorine: 15
Bromine: 0
CYA: 0
pH: 10
TF-100:
Calcium: stopped at 71 drops, > 1,175
Free Chlorine: 38 ppm
Alkalinity: stopped at 80 drops, >700
CYA: Unmeasureable, I was well below any of the measurements and it's not linear so can't estimate. >100
Combined Chloramines: None
Test strips:
Hardness: 350
Total Chlorine: 25
Free Chlorine: 15
Bromine: 0
CYA: 0
pH: 10
TF-100:
