As I have the past few years, I started seeing stains from the returns on the liner as temps come up. In the past three years I’ve just bought a bottle of vitamin C and stuffed them in a sponge that had a slit cut into it.
This year I bought a bottle of powdered ascorbic acid. Following the instructions, I vacuumed, stopped the pump. Sprinkled the ascorbic acid around then brushed. 24 hours later pool is gorgeous. It stayed that way for about a week.
I took measurements and my chlorine was high ~12 so I shut the swg off for about 4 days. I noticed that the light green was coming back along with the staining on the steps.
I realize I probably need a sequestrant at this point, or am I looking at a pump out and refill?
I did note that I now have combined chloramines whereas I normally don’t. I’m thinking that can be related to the ascorbic acid treatment.
Casa De Conwell
Build Type: Vinyl
Volume: 14500 gallons
Latest Test Result Summary:
FC: 6.0 (15 minutes ago)
CC: 1.0 (15 minutes ago)
pH: 7.4 (15 minutes ago)
TA: 60 (15 minutes ago)
CH: 220 (15 minutes ago)
CYA: 50 (15 minutes ago)
SALT: 3600 (15 minutes ago)
TEMPERATURE: 70° (15 minutes ago)
CSI: -0.81 (15 minutes ago)
Test Results 04-12-2023 @ 05:30 PM
Free Chlorine: 6.0
Combined Chlorine: 1.0
pH: 7.4
Total Alkalinity: 60
Calcium Hardness: 220
CYA: 50
Salt: 3600
Temperature: 70°F
CSI: -0.81
Casa De Conwell
Build Type: Vinyl
Free Chlorine: 6.0
pH: 7.4
CYA: 50
Salt: 3600
Temperature: 70°F
CSI: -0.81
