Hi. I have an ~30k gallon vinyl pool with an SWG. I am unable to get rid of the algae consistently. There are times it will subside then other times it starts to pick up again on the walls/deep end removable ladder stairs. The pool water itself is mostly clear, a little cloudy towards the deep end. The algae is on the the vinyl surface/ladder stairs. I replaced my T-15 cell (it was 14 years old) 2 weeks ago and the main board last season. SWG displays salt at 3800 and voltage/amps show it is generating. Below are the test results I ran this morning with TF-Pro Salt kit. I know the Chlorine levels are low but I just spent the last week slowly adding CYA as the pool was showing very low. Hoping they raise now that the CYA level is much better.
I am at my wits end (and a lot poorer). Any help would be greatly appreciated. BTW, the main stairs (white) will also at times start to turn orangish. If I sprinkle vit. c on them, it immediately cleans them. Thank you.
FC - 1
CC - 1.5
Calcium Hardness - 25
Alkalinity - 90
CYA - 80
Salt - 4000/4200
PH - 7.3ish (between colors)
FC - 1
CC - 1.5
Alkalinity - 90
CYA - 80
Salt - 4000/4200
