- Feb 6, 2015
- 6,169
- Plaster
- CircuPool RJ-45 Plus
You need either a Taylor K-1766 salt test kit or the TFTestkits salt test ( TF Salt Bundle )
Once you know the salt level of your present pool water, add enough salt to get to about 2800-3000 ppm salt. Use PoolMath to determine how much salt to add.
After the salt is added, brush in until it's dissolved. Run the pump for 24 hours after all the salt is dissolved and test the salt again. If in range, fire up the SWG.
You can work on raising the CYA at any time - now or later. Starting the SWG is not dependent on having the CYA at 70.
Use liquid chlorine to keep the FC within the target range as recommended in the FC/CYA Levels.
