We purchased our pool and hot tub Riverfront home almost 9 years ago. We had them renovated with glass tile around the waterline of the pool and the entire raised hot tub with "edge water" that allows you to overflow the hot tub into the pool We have a Hayward aqua control system with two pumps, 2hp blower and a Jandy gas heater for the hot tub that replaced the original Hayward heater.. The raised hot tub's tile has shattered under the summer sun. along with huge salt calcium build up and tiles falling into the pool. In only 8 years it has just fallen apart, still usable but not attractive at all. we are at the point we need to have the hot tub part redone. something that will stand up to the South Florida sun. We hardly use the pool in the summer due to it overheating, some summers going up as high as 94 deg. I have added sun sails this winter with about 90% cover but the water is already up to 78deg. is is only going up. Ideally we would like to keep the pool water 75 to 76 deg, to contrast with the hot tub set to 104 deg. I have seen the ad's for pool heat pumps and chillers, Ideally we would want a heat pump that cools the pool by transferring the heat into the hot tub. and only discard cold or heat into the air when one set limit is reached. but I don't see anything like this on the market. My gas heater works great for about $50 to 60 bucks worth of NG per month. is my only real option to add a chiller to my pool side and just keep heating the hot tub side with the Jandy? is there no dual heat pump available? I hope someone knows more so we can make better decisions for the renovation. Best regards Logan..
