Been TFP’ing for 2 months now. Pool gets pretty much zero shade from the Houston sun. I’m definitely noticing the change in seasons. I’m dumping nearly a gallon a day (today 14 cups), up from less than half that amount several weeks ago. I measure and dose at night. My CYA is 50 so target FC is 6-8 and minimum is 4. Using Pool Math, I had been inputting 7ppm as my target to calculate bleach amount to add. I’ve now had to raise that to 10 so that when I measure FC the next evening it’s still around 5ish and hopefully no lower than 4. I can see that in another 6 weeks in the height of summer, I’m gonna have to tell Pool Math my target is 12 or 13 so that FC doesn’t fall too low for the following day. That means even MOOORE bleach. Man!
So, does losing 5-8 ppm FC in Houston in spring and into summer with a zero shaded pool sound right?
FYI I’m using (allegedly) 12.5% from pinch a penny.
