I've got a DIY concrete pool that I've built and I've used epoxy + polyurethane to paint it for the past two years... It all falls apart and now I want to scrape the whole painting and put some tiles... The pool is with chlorine and heated up to 38 deg c - 100f deg, but mostly kept around 35c/95f. Family pool with a SPA area, kids are also using it. Depth is 160cm to 40cm depends on the side.
I want to use mosaic tiles, should I use glass or ceramics?
Thanks!!!
Thanks!!!
