Hi All! My CYA was at 35 last fall when I closed the pool. I had it tested at pool store at they say it is at 5. I read where I shouldn't be adding cya or testing it unless my water is at least 70 degrees. It is 59 right now. We've had COLD spring in Saline MI area. Should warm up this week, but don't have new solar cover cut yet.
I'm wondering if the low cya number is due to the coldness of the water tested. Also, does the water temp also impact the other tests? pH, etc?
Today's tests results were:
pH: 8.2
FC: 6.6
TC: 6.8
TA: 133
CYA: 5
pH: 8.2
FC: 6.6
TC: 6.8
TA: 133
CYA: 5
