- Jul 15, 2012
- 614
- Plaster
- Hayward Aqua Rite (T-15)
Biggest question I have before I start is how to deal with significant upward pH drift (or should I not be concerned). During the season, I was adding almost 2 gallons of acid every week to bring pH to 7.6 or so (and I would let pH drift back up to 8.1-8.2). Between my chlorinator and the new plaster, I assumed this was normal. But I have had the heat off and water temperature in the low 60s and dropping now to the 50s for a month now (with the chlorinator off) and the pH is still drifting upward (from 7.6 to 8.3 over last 3 weeks). Assuming I close at pH 7.5 or so, I am pretty certain the pH will drift back up. Should I be concerned and add acid during the winter?
The pool is not covered. I am in the northeast and it will freeze for 6 weeks or so most winters. Other chemistry is pretty stable (calcium drifts downward from rain water but this should stabilize after I drain levels and turn off autofill).
Current chemistry:
FC: 3.5
pH 8.3 (I added acid today to bring the pH down but need to purchase more to get it to 7.5)
TA 60
CH 325
CYA 50
Temp 55
(I will note also that to my surprise, the natural drive in FC was only from 7 to 3.5 without me adding any chlorine - my pool gets little sun after September 30 and the water has been sub 63 degrees the entire last month)
Second question: In multiple prior years, the DiamondBrite finish on the top step has cracked over the winters and needed repair in the spring. When pool was refinished, contractor told me that this happens when the DiamondBrite dries out because top step not covered by water in winter. Is there a way to deal with this issue? Should I let the water sit at a higher level and prepare to pump the levels down if needed during the winter? Are there other ways to keep water on top step? Or is the contractor just making excuses for some other problem at my pool? The step was redone 4 times over last 10 year because of cracking.
Current chemistry:
FC: 3.5
TA 60
CH 325
CYA 50
Temp 55
