I am going salt for the first time and just got a new liner. Salt test kit is on order and is a K1766 kit. The unit is a CircuPool RJ-45. It should be here Friday. Pool is filling now, and based on what I know about our pool guys, I can probably start running the filter on Tuesday. I’ve been reading and reading and now everything is running together.
1. Salt – Unless we have salt in the water, we are going to need 18 bags to get the level to 3500. We’re going to get the initial batch from Leslie’s because it’s close by and they keep a large supply. It’s $10 a bag, but none of the other places like WalMart or Lowes have that many bags.
a. In the future, is there any salt you would NOT recommend?
b. How much salt can I put in at a time?
c. How long should I wait to check the level after adding?
d. I’ve read to pour it in the shallow end and use a brush to move it around.
2. Stabilizer
a. How much can I add at a time?
b. How soon should I test after?
c. Yes, I know about the sock thing.
3. pH
a. Same thing, I never know how much I can put in at a time. In the past, mine has tended to inch up.
4. So, for CYA of 70 – 80, FC of 4 -6 is good? I think I’ve seen other levels mentioned for this.
5. Can I do everything else and then just add borates after the SWG is up and running?
6. If I get all the levels right before the unit is installed, I can add bleach to keep the FC up if necessary, right?
7. The unit, not the control panel, will be in the sun. Is that okay or do we need to figure out something about that?
Yes, I have a great test kit. They were sold by Ben Powell at Pool Solutions, and I have bought new reagents from time to time, so it would compare with one of the really good ones that you guys are using.
Any other comments or suggestions would be really appreciated.
2. Stabilizer
3. pH
