I have a 27000 gallon pool, gas line is 1", and want to know what btu heater I can buy and what brand or model? Thank you!
How long is gas line and what is your service pressure?
Gas co will be able to tell you what your system pressure is.
Typical pressure is 5-7" wc
1" pipe at 50' would handle 177k btus
For that size of pool, I'd recommend a 400k btu heater.
We're all very happy with Raypak brand heaters.
Less components and very simple repairs when they need service.
Is the length from the gas meter in the lamp post to the pool heater? IF so it is about 80' away. I called the gas company and they said 7 wc. So the only wat to get a 250but is to increase it the line to 1 1/4"? Is that internal dimension?
Will this heater work? In the instructions it say 90ft. at 1" pipe. If I'm only using this for gas at the time and not the furnace will it be ok? Where is the cheapest I can get this?
Raypak Digital Natural Gas Pool Heater 200k BTU Electronic Ignition P-R206A-EN-C 009216 P-M206A-EN-C 009962
Raypak Natural Gas Pool Heater 200K BTU | 009962
