- Jun 1, 2018
- 13,971
- Vinyl
- Hayward Aqua Rite (T-15)
I sooo wish I had a cover lift!Spa is back up and running. They replaced a power board (hope I understood correctly). Couldn't fully install the heat pump because they sent different pipes that were too small, so they'll still have to make another trip.
Good news is that my fill water is now crystal clear. That should teach me to clean the filter more often!
Did the acid/aeration dance for a good two hours yesterda. I estimate TA is now around 90 so I still have a bit to go. Using muriatic acid 10% this time around.
We also had the cover lift installed...man, does that make life easier!
I have a round tub & it’s at the corner of my patio right where the support pole is so I haven’t found a good solution
So this is how it sits when I am using the tub, kinda leaned up against the pole & the tub.
I flip it open then get in & push it over the edge. When I’m done I tilt it & pull it back over while I’m in the tub. My husband basically throws the whole thing in the yard then its a pain to deal with.
