I upgraded to VSP pumps this past summer and am now programming the freeze protection. I'd just like to confirm that it's safe to run the pumps at a low speed. The goal is to save power and not annoy the neighbors if we have another Texas freeze like last year when they have to run for days on end (although the VSP pumps are much much quieter than before).
Also, the installers set the priming speed lower than the normal operating speed. Does that makes sense? The pumps prime just fine. Is there a rule about priming speed, like as low as will actually prime the pump?
Here are the settings:
Filtration - Min 2450 Max 3295 Priming Speed 2500 Priming Duration 2 minutes
Pool 2850 Spa 2750 Pool Heat 2450 Spa Heat 2450 Freeze Protect 2500
Water Feature - Min 600 Max 3295 Priming Speed 2500 Priming Duration 3 minutes
Speed1 1750 Freeze Protect 2500
The water feature pump runs a waterfall and sprays on top of the pool slide.
Does it seem reasonable to lower the water feature to 1750 or even 600? It's just a loop with the two outlets.
The filter pump min is set at 2450 and I assume there's a reason for that -- maybe the heater or sand filter? I'm not planning on messing with the min setting on that.
