This is my first winter with a filled pool. We didn't actually have a freeze last night, but it got cold enough to set off the freeze protection. Unfortunately, I awoke to find no power to my pool equipment due to a flipped breaker. I have my main pump plus 3 waterfall pumps that are all set to come on with the freeze protection. All pumps run fine simultaneously, but I realized that I have never tried to start all 4 pumps at the same instant. I think this happened when the freeze mode kicked on, and since the pumps draw more amps on startup I suspect the circuit overloaded and the breaker flipped. Has anyone encountered this problem before? I know the simple solution is to call an electrician/PB and get a larger breaker installed. I'm just looking for any suggestions in the mean time other than purely manual control. I'm going to try to set my main pump to run at night, so hopefully with one less pump to startup I might get lucky...
