The freeze protect setting on my system keeps turning on and running my equipment when I don't want it to run. Wondering if any of you have had this issue before and trying to find the most likely equipment problem.
The controller says the air temperature is 33 degrees (I live in Houston, where it has been 100 degrees for the last four months), so the controller persistently tells the system to run.
The controller is the Zodiac/Aqualink/Jandy 8265. All of my other equipment is Jandy. Is this more likely a problem with the sensor or the controller? Advice or troubleshooting tips?
