JohnN
0
Don't worry about TA. It will come down as you keep your pH in line. Whenever your pH gets to 7.8, lower it to 7.2 with muriatic acid. This will, over time, bring the pH down. For a CYA of 50 (if that is what your true level is) your FC is at the very minimum. You should never let it drop below 4.
