I don't know why yours is taking so much longer to clear in terms of visibility than mine did...is most of the debris gone from the floor? Maybe instead of filtering on low at night, filter full bore? Maybe floc?
I have a sand filter too, so I know they're slower, but mine's also a 220T, my pool's roughly the same size, so the only other variables would be that you're not using floc, that you're turning your filter low at night, and that you're in Florida, where presumably it's warmer right now than it was in Michigan in April.
Mine was 12 days with about 4-5 lost due to no kit. You must be itching to see the bottom!!!
Maybe don't brush or anything now because you need to let that particulate SETTLE so that you can vacuum it to waste. Could be that you keep stirring it up. Let er all drop now so you can finish it in a pass or two
