Sounds all good to me.
My best shot at your questions. I don't know about laying the foam board so it won't be seen other than cut it very close to pool size and then cover it with landscaping material.
As long as they're level you're good. To be sure they won't crack, use 4" thick pavers.1) I will place/lay pavers at each vertical upright (forgive me if my terminology is incorrect!) - any tricks to this aside from using a transit?
I'd say not more than an inch. Sand can wash away so you don't want it supporting the pool, just filling in irregularities in the ground. Pavers should be level with the ground ideally, or just 1/2" or so above to make up for the extruded foam underneath.2) Based on the paver locations (relative to the ground height), I will level the existing ground/add sand as required (I have a few ideas for doing this but again, it's pretty flat already) (how much sand is recommended?)
No idea - I live in the desert.5) I will lay a vapor barrier plastic between the ground and the foam (what mil plastic is recommended?)
Most people seem to agree it is not necessary - it will just decompose. I wish I had just set mine on the foam.7) After the foam is laid I will install a tarp or pad (not sure yet if this is necessary)
