A month ago a bulk water company topped up our pool. Immediately once starting the pump, it started foaming. A thick layer of foam started when no chemicals were added as I always vacuum first. After a month, it's still there.
Water tested weekly by independent pool companies and shows all normal ranges.
Shocked, applied algaecide weak weekly, and it still foams. Vacuum on waste, backwash on waste, rinse on waste and still foam.
Tested TDS and normal range.
Believe pool company cleaned water truck before adding my potable water. Or used septic truck, cleaned it, then added my potable water.
Any ideas?
Any ideas?
