It is efficient, responsive and powers both 8 foot sheet- style water falls very well.
My equipment is about 50 feet from the pool and around the corner of the house. This pump is loud.
What speed do you run the pump?
How much flow is required for the water features?
Pumps are loud at RPMs above about 2,500 RPM, but there can be reasons for excessive noise like cavitation if the suction lines are too small.
If the suction side head loss is greater than about 17 feet, then that can put the pump at risk of cavitating.
For the 5 hp commercial WhisperFlo XF, the minimum suction pipe size should probably be about 4".
For 16 feet of sheers, you need about 200 GPM (16 foot at 12.5 GPM/Foot) for good projection.
If the lines are sized correctly, then the pump should be able to provide 200 GPM at 3,000 RPM or slightly lower.
Pipe Size and Flow Rates.
You want to keep the water velocity below 6 ft/sec on the suction and below 8 ft/sec on the pressure side of the pump.
Pipe Size | 6 ft/sec | 8 ft/sec |
1.5" | 38 GPM | 51 GPM |
2" | 63 GPM | 84 GPM |
2.5 | 90 GPM | 119 GPM |
3.0" | 138 GPM | 184 GPM |
4.0" | 235 GPM | 312 GPM |
Note: NPSHr (Net Positive Suction Head Required) is the minimum pressure at the suction port of the pump to keep the pump from cavitating.
The NPSHa (Net Positive Suction Head Available) is 34 - head loss at sea level.
At 200 GPM, the NPSHr is 20 feet, so the NPSHa has to be higher than 20 feet, which means that the head loss has to be below 14 feet (34 - 14 = 20).
For a 3" pipe (100 feet total equivalent length) the head loss is about 7.9 feet (Dynamic).
You also have to add the static head loss, which is the height of the pump inlet above the surface of the water.
To avoid cavitation at 200 gpm and 3" pipe, the pump cannot be higher than 6.1 feet above the water.
