In my opinion, this is not an issue at all.also to ensure that the pump does not exhaust its capacity in suction side , since the non-return valve is exposed to high hydrostatic pressure due to the pool.
You have a flooded suction because the pump is below the surge tank.
As long as the pipe is sized correctly, the head loss and NPSH are going to be good.
The back pressure on the check valve is only the height differential from the surge tank water surface to the pool water surface, which is 1.4 meters (4.6 feet or 2 psi) when the pump is off.
This will keep a vertical ball check valve or a vertical swing check valve closed.
Once the pump is on, the check valve opens and the water will flow without a problem.
