Flexible hose
tulpa
11
Northeast
I used this for about 2 seasons. It is supposedly designed for above-ground pool systems. I sprang a large leak splitting wide open. Very lucky it basically happened in front of us.
Can you recommend a flexible 1.5" hose that would hold under regular pump pressure?
I looked around quite a bit. I did not find a hose that is schedule 40. I guess you could replace that hose once a year since it lasted two seasons this time.
Many people hard pipe their AGP using schedule 40 PVC for that reason.
Reactions: Mdragger88
Many have issues with hoses & their connections- thankfully mine have been ok for 5 years.
I am currently still running 1 that came with the pool
Aqua Select 1½-Inch by 6-Foot Durable and Flexible Pool Filter Connection Hose | Connect Your Pool Filter Vacuum Hose to Your Pool Filter Vacuum for Above Ground Pools Amazon.com
& one of these
JED Pool Tools 60-345-06 Deluxe Filter Connecting Hose for Swimming Pool, 1-1/2-Inch by 6-Feet Amazon.com
I also have some hard pvc pipe as well as some flex pvc - the flex pvc is glued like regular pvc so you would need slip fittings to use it instead of the barbed ones.
Sealproof 1.5" Dia Flexible PVC Pipe, Swimming Pool and Spa Hose Tubing, Schedule 40, Pump Filtration, Made in USA, 1-1/2-Inch, 25 FT, White Amazon.com
