Hello!
I have lurked here at TFP for awhile, and wanted to post as I am starting to get more serious about my pool. Some brief background here: I am the second owner of this home and pool. The pool was remodeled in 2016 which included pool resurfacing with pebbletec, and some equipment changes. The best way I can sum up the issues is that there were several installation and maintenance companies involved that all made poor choices. We have been the owners for almost three years now, and I had some projects planned for this winter and spring before the swimming season starts here in SoCal. However, a surprise pump failure is now adding to my list of issues. I have a pentair easy touch automation system and a recently rebuilt intelliflo variable speed 3.56 pump.
1. The plumbing is a mess. There is a 90 degree elbow coming right off the return of the pump. The lines wrap around the filter before entering, and then wrap back around the the gas heater and solar heater systems. Both the pump and the filter are sitting on the dirt/mud. The old SWCG appears to be installed on what appears to be a decommissioned section of plumbing, but I don't know for sure. There is a pin hole leak on a return valve joint. I plan on digging a lot of this out, and replumbing by the equipment section, and adding either a concrete pad or concrete block for the pump and filter. See the photos. What would everyone else do here?
2. This next part might be more of a post for the automation section of this site, but I have some issues here too. Most of the automation functions were not set up when I bought the property. The solar heater valve was manual control only, and the valve for the vacuum was programmed at 100% so it caused a lot of cavitation. I'm pretty confident that the programming issues are fairly well sorted at this point, but I'm open to input. The pentair easytouch panel was piggy backed off the original electrical box that had a basic 24 hour timer and switches for lights. The pentair panel is not actually being used as a load center, and instead just has all of energized wires stranded together with some nuts. It's slightly better now that I have reinstalled the pump as the all of the connections are tight, but it seems pretty sketchy to me. I was thinking about trying to remove the old box, and simply wire up the pentair panel as the load center. I do need to figure out if the SWCG is wired for 110 or 220. From my home's main panel, there are two 20 amp breakers that feed the original pool control box. The heater is powered by a separate dedicated circuit from the main panel, which seems like a wasted run. The other issue is that while the lights are GFCI protected from the old box and operated by the relays in the pentair panel, the actual pump is not gfci protected. I live in a semi-rural area, so there aren't many pool equipment professionals. I have used one in the past that came highly recommended who replaced the filter canister, but he ended up making the plumbing even worse than it is now. I'm at the point where I'm ready to get my hands dirty to fix everything. I am not an electrician, but I have access to one that can advise me, or do the work for me if i can't figure it out.
After reading the above, and looking at the photos, what would everyone do with this setup?
