- Sep 2, 2022
- 22
- Fiberglass
- Pentair Intellichlor IC-30
Hi, I've been seeing some air bubbles coming out constantly from the return jet. Did some research and changed the strainer pot head's o-ring with the OEM (pentair) part. Still, the air bubbles kept coming. Then the second step was to change the o-ring of the suction side union. I read it should be hand-tight but I am not able to loosen it. Also, do you know the unscrew direction, I have been trying anti-clockwise (like in the picture)? What tool can I use to open this without damaging anything?
Also, any other thoughts on what's causing the air bubbles?
Thank you in advance.
