Hey all!
Sad to say, it's end of season here in WI.
This year, I installed an Aquador, since my house uses a well and I'd rather not put excessive strain on it next spring. I've currently got my winter cover on and the water level towards the lower mark on the skimmer, but am noticing that the Aquador seems to not be sealing. I've tried removing it, cleaning the flange, lubing the channel of the lid, and it still leaks.
Anyone have similar issues with leaks like this?
Also, if I can't get it to seal, is there any harm in draining the pool water level to the bottom of the skimmer (below the vacuum port) but NOT 6"? I will leave the bottom of the skimmer open. All of the equipment is still hooked up, so I can drain more water if needed, but I prefer to drain as little additional water as possible.
Last but not least... I read about someone who used a plastic barrel instead of a pillow under the cover. I didn't research it too much but I had a barrel and no pillow. So I currently have that under the cover. Does anyone see a problem with this/should I take it out?
Edit: While grilling dinner, I was also wondering how common it is for the winter covers to "seep" water through. It has been dry here, but there's a small amount of water on top of the cover.
