Hello
We purchased our house a week before the pool needed to be closed last year. We were anxious to open it, and youtube and forums made it look relatively simple. Of course it wasnt..
Wanted to see if someone might be able to help with a few questions, or point me in the right direction.
1. When we were ready to turn the filter on, water was pretty aggressively coming out of the sides at the band clamp. Do closing companies typically loosen this bolt for the winter? I tightened the bolt as much as I could with a wrench (is that ok?, should it be as tight as possible?) and knocked the band clamp with a mallet to tighten a bit more, but still getting a good amount of water coming out of the sides. Maybe an O ring issue?
2. The return jets that we have do not have threads. They are just a little bulb, but borderline impossible to get into the spa. There is a pvc pipe I can see in the 6 spa holes, but forcing these in isnt working. Tried some lubricant as well with no luck. Is there a trick to these, or just keep forcing?
Attaching pictures if helpful.
Thank you!
Thank you!
