Well, my first no drain water exchange is complete. Based on what I can see on my first post-exchange tests, I think it worked just about as expected.
According to my calculations, I replaced about 5,800 gallons of water, which is about 25% of my pool volume plus a ~10% buffer. It took 21.5 hours at 4.5gpm.
Here are the results:
- CH: 550 -> 450. Exactly what I expected. Fill water is 150ppm so a 25% replacement should reduce by exactly 100ppm.
- CYA: 60 -> 40. Pretty much what I expected. A 25% reduction would be 45ppm but since the test only goes in increments of 10, I think this is about right.
The only unexpected result I had was TA, which dropped from 80 to 50. Fill water has a TA of 40 so I would have expected to come out around 70ppm, but I'm guessing there are some more factors behind TA. My plan is to give it a little bit to balance out and then possibly raise it a bit if needed.
I wish I could have gotten CH down a little further but I think for my first attempt this was good. We'll see how quickly it raises back up and go from there.
The only thing I will probably do differently next time is try to schedule it in either to hotter part of the summer or a colder part of the fall/winter. Since the temperature differential between pool water / fill water needs to be as high as possible, picking a time when the pool water is at its extremes seems like a better idea. In my case, I had to heat the pool up a good bit to make sure the temp was high enough when I started. But, as
@Dirk has pointed out, I need to avoid Dec-Feb so my sewer bill doesn't go up year round as a result of using too much water in the winter months.
Thanks to all for all of the advice on this thread.
