travisr FIRST congrats on new rating !!!!
I had to raise my CYA up recently from "0" after all the rains we had earlier in year. Look at the bottom of pool math and insert in the tool how many ounces of pucks you have added ( normally 8 oz peer 3 inch puck ) and it will tell you how much it will increase CYA. I turned up my feeder all the way and it dissolved them in a few days. Might as well using up those pucks! I also went through the new pool start up but with no help from PB. TFP helped me get everything started and running crystal clear. I also have a spa with the spillway and the water features on my wall also. Alot of aereation so kepping pH correct took awhile but has stabilized in the last 4 months. The Stenner makes life alot easier! Where are you getting your 10% bleach from?
Thanks! That 8 oz per 3" puck was what I was looking for.
Texas, I'm going to count how many pucks are in the total system when I get home and see what that should put my cya at then add cya accordingly. That oz/puck number was what I needed. Hmm... thought it was sock in skimmer. Assume either will work?
