Re: First SLAM - persevering...
Tested the water and am very confused by the results because they are much HIGHER than I expected!!
I just tested the water twice (once with the 5ml of water method and then again with 10ml of water method to double check) and both times the FC reading came out close to 40!!! So, now I'm wondering if I somehow misread the test results from this morning (meaning FC was higher than 28 to start with). If I really started with 28 ppm this morning and added 2 gallons of 10% chlorine, then a result approaching 40 tonight makes no sense based on what I thought my pool size was, so either the 28 is wrong, the 40 is wrong, or my pool size estimate is wrong.
Wondering if I am doing the testing properly and what parameters might affect accuracy/consistency of results.
Firstly, the kitchen light over my sink where I do my testing is a high-efficiency bulb that gives off a cool/bluish light. This is the main light illuminating my workspace at night. In the morning when I'm testing, yellowish sunlight comes through that same window quite brightly and even though the same lightbulb is on, the intensity of the sunlight overwhelms the bluish color. Could the color difference in the light affect my perception enough to affect the accuracy of the FAS-DPD test?
Second possibility, maybe just grasping at straws, but would the extremely low temperature of the water this morning affect the test accuracy?
Thirdly: how much DPD powder should I be adding? Heaping spoonful isn't very specific and I read that higher chlorine levels could require more, so I've been adding extra (like maybe 3 level spoonfuls of the little blue spoon that comes with the kit when I do a 10ml test and 2 level spoonfuls when I do a 5ml test). So again, could that be skewing my results?
Feedback please!
