Finally removed inop light for analysis - Pentair light dated June 2004
Failure! Water in the housing. :grrrr: We did see, over time, a couple of large bubbles (like big burps) exit the light. Saw that mentioned in the old thread referenced above.
The water is filling about the first 2 inches of the housing (draw a line from8 to 4 on a clock face) which probably corresponds to about the level of the cable connection in the back. This is exactly the same level the light had filled to before the new gasket. Would I be correct to assume the leak has to be at the cable connection because of the level of the water in the housing? It's only fills to the level of the leak?
