Question for you all that have done the upgrade to a Hayward skimmer, but kept the standard 12" sand filter and pump. I did this conversion a week or so ago now and immediately upon flipping on the pump post-conversion my pressure was about 20% higher. For those that have switched to a skimmer that has a 2" (actually 1.5" I.D.) hose connection to the pump, did you all notice an increase in pressure?
I have the SF80110-2, which has a maximum working pressure of 30 PSI. Before the conversion, after a backwash and rinse, I would sit around 5.5-6 PSI. Now, after a backwash and rinse I am at 7 PSI. Which is where I was immediately after the conversion.
I also went ahead and did the almost "unthinkable" today and changed my filter sand. I know, I know. Sand can technically last a lifetime. However, I have multiple reasons to go ahead and just change it.
TIA,
Daniel
EDIT: Added a pic of what I’m dealing with on the bottom. This was a few days ago. Today is less. Tomorrow maybe more. It’s a constant battle.
- I had a 50lb bag of #20 Silica just sitting around from the previous owner (they thought you were supposed to change it like ... daily? [LOL. JK.. but no, they had several bags, no idea why.]).
- I have been battling a super stubborn algae to where I have been in SLAM for 11 days now. I FINALLY passed OCLT last night, but there are still some brown spots on the bottom [likely dead algae], so I technically am not out of SLAM yet.
- Every single time I shut off the pump for more than 2 seconds (literally), and turn it back on, there is a good amount of a brown "plume" from the return for about 2-3 seconds. I know, this could be a number of things. So I wanted to eliminate a few:
- Broken / cracked / damaged spider gasket. (nope, it's good!)
- Broken / damaged 6-way in general (nope, it's good!)
- Broken / damaged lateral (nope, they're good too!) --- This was the main reason to just go ahead and replace. wanted to check. I know, I wasn't catching any "sand" in a panty hose when the brown plume went, but I wanted to check it anyway.
- Possible channelling. Since I would need to deep clean the sand anyway to help break it up, might as well just swap it.
- The sand had some of that Clorox Sand Plus (I assume zeolite) mixed into the #20 silica. So it was some sort of "mixture" of the two. I didn't realize this stuff wasn't actual sand until I was pouring it in, I was low on sand (again, part of the reason I thought there was a problem. But thinking back, I think it was low when we got it last year from the previous owner). So, battling algae, I wanted to top it off. I also didn't know you were supposed to "pre-wash" it. Alas, mistake made and lesson learned. Returned the very, very slightly used back to Lowe's for refund. They didn't mind at all, said it's a very common issue / reason for return. While probably not "a huge problem" that it's a mixture, my OCD doesn't like it. I've also read the zeolite may actually be putting dust and other particles back into the pool. I posted some pics in another thread of what I am battling every day on the bottom of the pool. Water is CRYSTAL clear. I passed OCLT last night, but have this stuff showing up on the bottom constantly.
TIA,
Daniel
