No idea what he was measuring.... kind of above my pay grade to know that stuff.Did the person measure the power or the power factor?
This is why I said that most people do not understand how to properly test 3 phase motors.
I'll check for this....The pump should have an arrow on the front that shows the direction of rotation as shown in this picture.
Can you ask them to provide a written description of exactly what they did with a diagram to explain what was tested?The technician that was here today said he is getting 13.9 amps on one side and 15.4 on the other.
On another matter....
Our pool company includes this in their annual service contract:
Clean Pool Heater (per manufacturer’s recommendations) $ 500.00 for 125 – 405BTU
We have 2 heaters. One was replaced this summer and the other was replaced last December. So $1,000 to clean both.
Is it a good idea to have this service done every year.... or could it be done less often? Is this service really needed for the heater that we just replaced? Is the price reasonable? I believe we can decline the service if we choose.
The technician was here mainly to install gauges that were missing on our system and evaluate the flow meter(s) and look for any other issues that may be affecting flow. He only gave me 2 numbers for amperage.... not sure why it wasn't 3 numbers. Nothing about voltage. I think the next step would be to have a competent electrician evaluate and answer the questions you are posing. If we can get that done for a standard service call, it might be worth it. I'm still waiting to hear back from the electrician I contacted. If he doesn't think he can evaluate and answer the questions, then I'll look for another resource. I have all your questions that I will be sure get answered by whoever comes out.It would have been nice if the person checking the power actually knew what they were doing and could give us the accurate information.
If they do not know what they are doing, they are just wasting their time and your time.
I would say it's close to that.... maybe more like 2 feet. I could try to get an accurate measurement.If the vacuum gauge is about 3 feet higher than the pool water surface, then the numbers look good.
We have a differential between 2 flow meters... one reading 160-170 and the other reading 130-140, so about 30 gpm difference. My understanding is that the engineer at the pool company is going to determine if 170 gpm flow rate through a section of the return line that has 1" pipe is attainable. If not, then the diagnosis is that the gauge is off and we have to replace it and see what flow rate we get with a new one. Since we are getting 130-140 gpm from the other flow meter, I would assume that one is accurate (if it's determined the flow meter with the higher reading is off). In that case, the question remains.... why aren't we getting the flow that the pump is capable of.... do we replace the section of 1" pipe (recommended by technician).... or focus on the operation of the motor.... or both?If you feel confident about the flow reading at 170 GPM and the pressure readings, then the pump seems pretty close to expected performance.
If you feel like the flow is not accurate, you can consider doing more to investigate to diagnose the problem or if there is a problem.
I have read the Illinois regulations which require flow rates that turn over the pool every 6 hours, so (60,000 gallons / 360 minutes = 167 gpm. My undertsanding is that it must run at that speed always.... not just part of the day. Several pool guys have told me that (when I asked about running at lower speeds). So.... 167 gpm is what I was trying to achieve when I became aware of this rule. We were at about 90-100 gpm at that time. Now (it seems) it is running at about 130-140 gpm (after pump service and a few other tweaks. Questions now is.... is that good enough? Do I leave it alone or continue to investigate.... and at what cost? I have been here 2 years and never seen an inspector. When I ask the question "Would an inspector shut the pool down if he sees a 130 gpm flow rate", the answer is "Depends on the inspector."In my opinion, 167 GPM is excessive for that pool.
I would think that you could easily go down to 2,500 RPM, which would be about 120 GPM.
The required flow rate might be just for when the pool is in use, which would mean that you could run slower during times when the pool is not open for swimmers.
It can be done, but it generates a lot of head loss.My understanding is that the engineer at the pool company is going to determine if 170 gpm flow rate through a section of the return line that has 1" pipe is attainable.
Excellent information! I am trying to track what it costs us per year to operate our pool and have a pretty good handle on most expenses..... except the utility costs..... electricity to run the pump and gas to run the heater. I googled electricity rates in Illinois and found this:If you decide to replace the pump in the future, it might be worthwhile going to a variable speed pump.
3.7 kw at $0.20 per kwh is $0.74 per hour, $17.76 per day, $124.32 per week, $538.72 per month and $6,464.64 per year (24/7/365).
At 2,500 RPM, the power should be about 1.4 kw or 1,400 watts.
1.4 kw at $0.20 per kwh is $0.28 per hour, $6.72 per day, $47.04 per week, $204.4 per month and $2,452.80 per year (24/7/365).
STATE | Sep 2023 | CHANGE (%) |
Illinois | 12.56¢ / kWh | -3.011 % |
Pipe Size | 6 ft/sec | 8 ft/sec |
1.5" | 38 GPM | 51 GPM |
2" | 63 GPM | 84 GPM |
2.5 | 90 GPM | 119 GPM |
3.0" | 138 GPM | 184 GPM |
4.0" | 235 GPM | 312 GPM |
Combining the electric supply charge and the transmission services charge, the ComEd Price to Compare effective September 1, 2023 is 6.799 cents per kWh. These Prices to Compare do not include the Purchased Electricity Adjustment, which is a component of the ComEd Electric Supply Charges.
