Hello to All,
My CYA is 40, and I want to bring to maybe about 50. Instead of Cyanic crystals, I was going to add a couple of pucks and was seeking folks recommendations on where to get them in the Hou/Katy area w the best value. If I recall, 2ppm CYA acid per puck. Don't need a lot of them, maybe 10-15. Can also use them when we travel for week+. I am using all HEB 8% liq CL and don't plan on going to pucks other than to raise CYA when needed and traveling.
Thank you very much, tstex
Other metrics are:
FC 5-6
TA 70 [this was 40 and added 8lbs of NaHCO3 to get 70
CYA 40
pH 7.5
CH 437.5 [17 to 18 div by 2 x 25 drops]
Other metrics are:
FC 5-6
CYA 40
pH 7.5
