Ive had a 18k gallon 16x32 inground for 8 years and all precious posts on tfp. Moved in september to a new place with a 20x40 34k gallon it has a heater, which is new equipment for me, and a little more plumbing. I closed it. Opened it up last week and have had air in the pump box, replaced that gasket, got a little better but still only 3/4 full at pump. Replaced the pvc line from pump to skimmer too (broke during closing). Pulled pump apart tonight and need to replace some gaskets and impeller was 1/2 clogged with seeds. The only place i potentially could have cracked is my skimmer, but that had protection (packed foam noodles) and probably never froze solid anways while above skimmer after snow melted
Im not sure it will fix my problem honestly but was considering replacing the pump to a variable to save $ anyways. Current pump is a 1hp superpump. Looked at the calculations and it seems appropriate for the flow rate of the filter, but maybe a little under for the rest of it.
All that said if i did it should i go with the 1.64hp or the .85hp variable?
Any other commentary on the potential air issue is welcome
