Hello all, Due to hurricane Erma i had to have my roof replaced . Roofing Co completed the job and a solar Co mounted my panels. The only issue is they said my controller is not functioning and needs replacement at $400.
My symptom is that my booster pump will not turn on so no water flows up to the panels, even if i flip the switch to manual/test. Controller is a Hayward GL-235-X244. Is it a failed controller or something else? How can i test?
If its the controller i can find a replacement on Amazon for $185 and replace myself.
Thanks for all you help.
