Hi all. Struggling with a pool that is constantly cloudy but has proper color (blue). Readings:
ph: 7.4
fc: 5.5
cc: <0.5
ch: 1025
TA: 50
cya: 30
Located in Rwanda, I've always used sodium hypochlorite 65 as my primary chlorination source as well as for slamming the pool. Liquid chlorine not available in large quantities here. My fill water is extremely soft at 50-100, and rarely do add since it rains a lot here.
My CH in the past was usually around 700 and I kept my TA low as well as ph usually around 7.4 Recently CH moved up to 825 or so but was managing the pool okay. Chlorine loss per day is 1.5-2 with not much overnight loss. Over the summer it barely rains here but don't add water that often. The pool's consumption of Cl was pretty consistent but never got that sparkling clear water in a while since late June. ph would creep up in the summer more than normal, (I would go weeks without adding any acid but in the summer with a lot of sun I would be adding almost weekly or biweekly to bring back ph down) I bit the bullet and decided to start slamming last week despite no OCLT but just with the pool being cloudy. Over the 6 days I was adding about 6-8 ppm per day. No OCLT but still cloudy. I checked the pool hardness and it was quite high. I decided to stop after 6 days since there was no change whatsoever to the pool in those 6 days. (in the past it would take 3-4 days to see some instant change)
Using Taylor's CSI wheel when I put in my info with water temp of 21C I get 0.3 or 0.4 but in pool math it shows balanced! I'm quite confused about that.
I decided to try adding acid to 7.2 to lower my csi more and see if that helps. the pool hardness is from using cal hypo for daily and slamming. I recognize that. I also recognize I may need to drain some of my pool but want to avoid that until next year when I hope to repaint the pool (acyrlic). Any thoughts?
ph: 7.4
fc: 5.5
cc: <0.5
ch: 1025
TA: 50
cya: 30
