- Jun 5, 2020
- 152
- Plaster
- CircuPool RJ-60 Plus
I cleaned my Pentair FNS+60 DE filter a few weeks ago and it has developed a leak under the belt clamp. I generously lubed the o-ring and have tightened the clamp so that the springs touch and even a turn or two beyond that. I believe the filter assembly was installed with the pool 20+ years ago, and I know the o-ring is at least 5 years old (that's how long we've owned the house). Should I expect to replace the o-ring every so often, or is this more likely a case where I just need to open it up and clean and re-lube the o-ring and filter assembly mating surfaces? Thanks!
