I recently removed the solar panels from my roof.
In doing so, I removed the valve actuator and temp sensor.
I cut and removed the wires to the actuator.
I now have NO action at the control panel!
Other than hearing a slight hum (from the transformer?), there seems to be zero result from switching the main breaker on. Jandy Customer service suggests checking/changing the 3amp fuse on the back board, but that didn't do anything.
Can you think of anything to check?
Thank you in advance.
Mike
Mike
